Thanks Brian & John for your efforts at "Brentwood Towers" oil getting the magazine together. It was really nice to see the late Alastair Brown on the front cover, which brought back some fond memories. Also the late Robin Allen, although I never met Robin, it was good to put a face to the name.
One nice little tweak you can make to the Comodo stalk is to add a modern electronic indicator relay, and still keep the Temsu "clic clac" device as an audible warning, but the best way to make the Comodo last is reduce the current across the contacts by fitting relays to the headlights as well. I've done this and the flaky tired Comodo has been restored. Some of the later versions have a headlight flashing function too.
Mike
Mike
...knowledge is nothing without imagination...
