• 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Sample thread...
#1
Hi and welcome.
Some sample text can be added here, and etc etc...and you can add styles, by clicking on the icons when you "Post Thread" (create a new topic), or if you want to reply using the "New Reply" button.
You can also add a picture, by going down to the bottom of this window, and selecting "Choose Files" next to New Attachment, and you can highlight text or leave as normal.
Pictures get inserted, once you "Add Attachment", you can click on "Insert Into post", and it will go where the cursor is when you click on this, but beware a poorly sized picture will dominate the webpage, and is very unnecessary. This was a 1.6Mb jpg, and it has blown the page! Smile
You can then add another... but try and think about the file sizes, and the resultant image size, as modern smartphones etc can have very large images, and this is the same one as above, but I cropped it to 640 pixels wide in the picture below, and it's still too big. :o
and there's hardly any difference between the two above, one is around 1.6Mb, the other about 800Kb (about 50% smaller in file size), but I've cropped the image to just 400 pixels wide for the picture below, and finally the webpage is holding up. A little thought when attaching pictures really does make a difference, and still gets the message across, without slowing everything down.
Thanks for reading & good luck posting
Mike
  Reply
Forum Jump:
Users browsing this thread: 1 Guest(s)
