Ignition problems?
This electronic ignition will solve the problems of the original Panhard ignitions.
After installing a SkyFire2 Ignition; starting, performance at low and high revs., fuel consumption and drivability will be substantially improved.
The SkyFire2 Ignition will be installed between the distributor and the high performance ignition coil.
The initial ignition timing can be set at 6 teeth (20 degr.) and the timing will automatically be adjusted upto 30 or 35 degr. as the RPM increases (example a Panhard 24CT.).
Some Panhard engines tend to pink easily. The timing of the SkyFire ignition will suppress pinking.
Re-adjusting the timing for starting is no longer necessary. You can fixate the distributor.
The timing map, which is installed according to the Panhard specifications or to your desired specification will be installed by the SkyFireignition. If you want more maps, a second map can be installed. Changing between the maps can be done with a switch. The maps (curves) can be 2D or 3D. The installation software can calculate form 10 map points a map of max. 60,000 points. Therefore the timing is very accurate.
The SkyFire2 Ignition can electronically compensate for RPM and depression. This will give the best ignition timing under all circumstances.
There are also special algorithms to stabilize the engine. This make it possible to put a EURO coin on a running 4, 6, 8,12 cylinder engine.
A special high performance ignition coil produces an extreme powerful ignition spark for a even more performance and lower emissions.
These features makes it often possible to start a cold Panhard engine without operating the choke.
More information on the website of the manufacturer: https://www.skyfireignition.nl/pages/what-is-it/
Some YouTube movies:
This movie shows is a cold start, without choke and without additional throttle.
https://youtu.be/6jHQmK5YNg4
This 2 cylinder engine will run perfectly This engine is running at less than 0.9% CO and 282 ppm HC.
https://youtu.be/FMukTReO2r8
This 1961 4 cylinder Land Rover SIIa with a EURO coin on the running engine.
https://youtu.be/6gPlIsTgYLM
